Originally Posted by 04-hellfire
I've had my car checked with obd11 scanners came back with code P0410 secondary air injection pump. The check engine light goes off and comes on it was off for 3 days and then came on and would not go out. Has anyone had this problem?
Code P0410 relates the air pump that injects air into the exhaust manifolds during engine warm up. It is located on the front of the engine and only runs for about a minute when the engine is started from cold. Code P0410 is thrown if the ECU fails to detect the pump in circuit so I would check the single two-pin connector that feeds the pump, and from memory I think there is a single fuse in the fuse box that feeds it which is also worth a look. It sounds like you have an intermittent connection to the pump. Have a look
here for more details.
