Old
BrianBrave's Avatar
BrianBrave BrianBrave is offline
Default Re: "Search" before you post - 11-27-2007 , 10:36 AM
Perhaps one of the moderators could make a FAQ section at the top of the forum and list the major subjects in a sticky that keep getting asked?
ie..
CrossfireForum.org > CrossFire FAQ Sticky (Read before you ask)
> Rotex Gold Brake Pad Part Numbers (and other low dust pads)
> Sprint Booster - (the must have qizmo)
> Oil Filter Part Numbers / Oil / Oil Change
> Air Filter Part Numbers - (not asked to much anymore)
> Extended Warranties
> Octane / Gasoline
Did I miss any?
Aero Blue SRT6 Coupe
Engine: SL55 Intake | 185mm Pulley | Iridium Plugs | Dyno Tuned | Air-Oil Separator
Cooling: Custom IC Tank | Coolant Isolation | IC Wrap | LET Heat Exchanger
Suspension: Lowered (Custom) | Front & Rear Camber Kits | Slotted-Dimpled Rotors | SB Brake Lines | ATE SuperBlue
Exhaust: Resonator Delete | Catalytic Hot-Swap
Instrumentation: Boost Gauge | IAT Gauge | Aluminum Pillar Mount
Speed Certificate: ..... <LINK>
