Re: Code P0453 Fuel tank pressure sensor/switch high.
Originally Posted by makeithappen
As said in the title. This code came up when i scanned when my check engine light was on. Has anyone had any experience with this code coming up? It would be much appreciated for any information and to see what others did about it.
Reading the shop manual Evaporative Emissions section 25-15, it looks like the EVAP purge solenoid is not working and the excess pressure is discharged via the filler cap. This purging would be a cause to fail any emissions test as you know. The code is kept on record, hence the engine light stays on.
See page 25-15 for a diagram of the Evaporation Control system.
The following is the full description of this fault.
P0453 Evaporative Emission Control System Pressure Sensor High Input
I am no expert by any means but it is always interesting to look at possible causes of problems.
