How to make your own low profile car ramps
permalink
02-26-2009, 09:26 AM
mrphotoman
Re: How to make your own low profile car ramps
Finished Ramps.
10" wide is good for wide tires.. Got wider ? You can get 2 x 11's if need be.
This is with the stock springs, but you can see plenty of room.
Drive on up
ON A FLAT LEVEL SURFACE, just drive up the ramps. The stopper piece will prevent you from driving off and each step is easily rolled onto. Then lay a wheel stop "behind" the front wheels and you are ready to work. Each ramp weighs enough so they should not slide when driven onto slowly.
If you are on an uneven surface, you might need to shim the ramps to get them level and to ensure they lay flat. You can also place jackstands as a backup if you wish.
What kind of lift
It raises the stang about 6" (a little higher than rhino ramps as an example) and it's high enough to do most under chassis engine / h-pipe work. Need higher ? You can add an extra step (before the rear tire hits the ramps even).
Like
mrphotoman
View Public Profile
Send a private message to mrphotoman
Find all posts by mrphotoman
