Re: How to make your own low profile car ramps -
02-26-2009
, 10:27 AM
The bottom line...
If you could not find yourself the "right" set of ramps in stores or are tired of jacking up the front end one side at a time or bending your center crossmember with your jack, or can't get a jack under your front end... you can see making a set of home ramps is fairly easy and you can make them to your very own specs.
The cost of the wood can vary, so these are not really "poor mans" ramps in some cases home made may cost a few dollars more, but since it's to your own specs, we like that :-)
We gave our ramps a coat of paint after these shots were taken.
Extra notes:
These ramps will weigh 30 - 40 pounds each depending on how dry the wood is, so they are mainly for home use (not really portable). We still have all our other ramps (Rhino, metal, 2 stage, etc) and use them when we can for different jobs.
Code3 Pulley_Inmotion Custom Tune_Needswings Intake_AIS Meth Injection
1/4: 11.86@116.76 1/8: 7.64@92.19 60': 1.70
Driven on the: Dragstrip/Road course/Street
