Old 08-17-2009, 05:32 PM
Airscape's Avatar
Airscape
Airscape is offline
Default Re: One headlight's brighter than the other? Ideas?
Had a similar issue and the bulb on my passenger side was just not exactly in place. It was making my driver side look really bright only because it was not projecting as straight as it should have been. If you look close at the headlight there is a little dark shadow right below the light (in your picture you can see it on the passenger side, little dark dot towards the grill). I do not see it on the driver side picture, when both bulbs were in correctly the dot was in the same spot on both sides (mirror style). Might want to pull the driver side out and pop it back in, might end up looking like the passenger side.
