Originally Posted by Airscape
Had a similar issue and the bulb on my passenger side was just not exactly in place. It was making my driver side look really bright only because it was not projecting as straight as it should have been. If you look close at the headlight there is a little dark shadow right below the light (in your picture you can see it on the passenger side, little dark dot towards the grill). I do not see it on the driver side picture, when both bulbs were in correctly the dot was in the same spot on both sides (mirror style). Might want to pull the driver side out and pop it back in, might end up looking like the passenger side.
Airscape you nailed this one!! The drivers bulb was actually loose... I mean as in broken away from the metal surround the clip holds down. I'll post a pic up soon as I just got in after 2.5hrs of work. Had to remove the whole headlight assembly to get the bits that broke off inside.
Thanks Again!
