Old 08-19-2009, 08:16 AM
maxcichon's Avatar
maxcichon
maxcichon is offline
Default Re: One headlight's brighter than the other? Ideas?
Originally Posted by 04Fire
Airscape you nailed this one!! The drivers bulb was actually loose... I mean as in broken away from the metal surround the clip holds down. I'll post a pic up soon as I just got in after 2.5hrs of work. Had to remove the whole headlight assembly to get the bits that broke off inside.
Thanks Again!
I knew this-just wanted to see if someone else could get it!
Good call.
