  #507 (permalink)
Old
LantanaTX's Avatar
LantanaTX LantanaTX is offline
Default Re: V8 Crossfire Conversion Diary - 10-14-2009 , 10:15 PM
Quote:
Originally Posted by oledoc2u
in the old days, I did away with my big block chevy to move to a small block in my camaro...now, you have done just the opposite...how does the front suspension look...and what is the weight difference...just curious....it really looks just like it was meant to be in there...really grt work...good luck with the start up...
Thre is no substitue for cubic inches. Back in my day I built a wild 351C for my drag car and raced it in NHRA B Super Modified. Back then we used alot of small blocks but Pro Stock was using small blocks because of the weight breaks and small blocks were more plentiful and getting all the good parts developed. When NHRA latter changed the weight breaks all of a sudden they were all running mountain motors. Keep in mind my new motor is an all aluminum 5.0L SOHC three valves per cylinder small block. I bet if you had a V6 Camero back in the day you would have put a small block V8 into it.
The car now weighs 100 pounds more but the car is still at exactly the same ride height as it was with the V6. My Vogtland springs may have helped in this area.
I did decide to remove the underhood insulation as it was rubbing on my engine cover. No problems now but as I mentioned before this is a very tight fit!
2004 SSB 21517, 2002 Mercedes CL500 V8 Engine, 2009 Mercedes SL550 wheels 18x8.5's and 18x9.5's, Vogtland Lowering Springs, Posi Quiet Ceramic Pads. Mercedes/Brembo CL500 Calipers, KYB Shocks, SRT rotors, Ansa Sport Muffler, HID's
