Quote:
Originally Posted by kanzus
Hi,
Many points you should check for car to start:
- First of all, control Drive Authorization System (DAS) in EZS menu and check if its active or not;
- control spark at coil wires;
- is there any fuel arriving to injectors.
Good Luck.
I was able to run Drive authorization until it asked me to start the car. when I tried to start the car the engine did not crank over. I can put power to the starter and it cranks fine so no problem with starter.
With key on injectors fill up with fuel. The center wire on the injectors is power up but we did not check this with key on. the strangest thing is that when I run dirve authorization, It displays the VIN readout from the car and the VIN readout from the ECU. BOTH VIN match and neither is my VIN. How is the VIN from car chassis a MB VIN? I cannot change the VIN from car, but I can change the VIN in the ECU.
