  #512 (permalink)
Old
kanzus kanzus is offline
Default Re: V8 Crossfire Conversion Diary - 10-15-2009 , 10:56 AM
Quote:
I was able to run Drive authorization until it asked me to start the car. when I tried to start the car the engine did not crank over. I can put power to the starter and it cranks fine so no problem with starter.
With key on injectors fill up with fuel. The center wire on the injectors is power up but we did not check this with key on. the strangest thing is that when I run dirve authorization, It displays the VIN readout from the car and the VIN readout from the ECU. BOTH VIN match and neither is my VIN. How is the VIN from car chassis a MB VIN? I cannot change the VIN from car, but I can change the VIN in the ECU.
Normally, DAS display VIN of the car on the right top on the screen, near Voltage, is it VIN of your car crossfire? or onother VIN ? MB VIN? (this is the case you enter DAS and run one diagnostic module.)
what's the status of your authorization (actual values --> in EZS menu) ??
I think you are near to the goal, fuel arrives, you have spark .. let's make authorization OK !
Wating for your reply.
