Re: V8 Crossfire Conversion Diary -
10-24-2009
, 07:02 PM
Quote:
Originally Posted by Jeep2Xfire
Generally starters get the ground from being bolted to the block. Is this not so??
In Volvo world (generally a car is a car no matter the brand) The key in the ignition is then turned activating the differing circuits (15, 15l, 30, and X-supply) as the key is turned from Positions I, II, and III. The immobilizer interrogates the key (even though they're laser cut, the antenna ring outside the ignition lock cylinder receives the signal from the key and sends to the immobilizer. Immobilizer then sends the signal to the ECM to power the starter relay thus supplying power to the starter motor. This is all Volvo speak though. Is it not the same or at least similar to Crossfire speak??
Justin
What you say is pretty much true but there is a starter wire in the power relay module that makes it way over to the electronics box where the ECU and body control module are. When this wire is grounded the starter engages.
2004 SSB 21517, 2002 Mercedes CL500 V8 Engine, 2009 Mercedes SL550 wheels 18x8.5's and 18x9.5's, Vogtland Lowering Springs, Posi Quiet Ceramic Pads. Mercedes/Brembo CL500 Calipers, KYB Shocks, SRT rotors, Ansa Sport Muffler, HID's
