re: How to Repair Relay Control Module (RCM) - (Mystery no Start)
I was wondering if the joints might see too much heat or if it's just a common defect. So far three out of three have had bad joints.
Folks. Might want to take a look at your RCM's before you get stranded! Don't say you weren't warned!
One of these days after a drive I'll remove the protective cover and check the temperture of the area of failure to see if it is higher than the rest of the board.
