Old 11-05-2009, 10:48 AM
onehundred80
onehundred80 is offline
Default Re: Removing pop rivets
Do not believe everything you read.
Its a snap .... really.
From the shop manual;
REMOVAL - TAIL/STOP
1. Disconnect the negative battery cable.
2. Remove the access panel from the cargo area interior trim
panel.
3. Rotate the tail/stop lamp socket (2) counterclockwise and
pull it from the tail lamp unit (1).
4. Remove the bulb from tail/stop lamp socket (2).
