a HID is the high intensity bulb that you had installed and you are referring to as a 'halogen' bulb... this kits 'USUALLY' come with a load resistor as part of the assembly and it is just a plug and play set-up and shows the car the same electrical load at the standard bulb....thus no 'bulb out indicator....
If your kit does not have a load resistor as part of it.... you will get the 'bulb out' lamp on your dash.... any other lamp being out will cause it also...side marks, license plate, trunk, turn signals, etc. etc......
installing LED's without a load resistor in place of factory bulbs will also cause a 'bulb out' indicator... i.e. side markers, turn signals, license plate, map light........
