Originally Posted by antonio311
Guys, it's always a good practice to let your car idle for 1 minute before shutting it off in your driveway....especially a turbo charged car. it allows the engine to circulate & cool down an engine especially after it's been driven hard.
Also a slight knocking clinging sound is normal upon shutting. As it's the exhaust system contracting after it's expansion during the heat up with the engine heat. It's a normal sound. Other knocking is not normal. Try a higher gasoline octane to limit engine knock & run-on after shut down.
Hope i helped a bit!
Thanks for the reply. My car is not a turbo and I understand what you are saying about the ticking of the cooling exhaust on shutdown. My issue is not those. I usually do let it idle a min. or so before shutdown. I am wondering why the clunk with the clutch pedal not pressed and no clunk when it is pressed in on shutdown. I have heard of thers with this issue I wonder if it is all 6 spds and is normal? I only run 93 octane. It dosen't sound good. Thanks.
