Old 09-11-2010, 06:04 PM
onehundred80
onehundred80 is offline
Default Re: HOW TO replace headlight bulb. Pictured step by step instructions
Originally Posted by Musclefan21
Ok guys, My driver side low beam went out and since last time it gave me a HUGE headache, I decided to to a DIY for it.
This is actually an EXTREMELY EASY job which can be done under 5 minutes. I tried to go into as much detail as possible for those who has no knowledge, so, they could understand it better.
Do this at your own risk.
Enjoy:
Looks like the passenger side to me. ( Edit ; OK you corrected the side now)
I did my driver side two weeks ago and the passenger side went this week and by coincidence I changed it today.
You are right, do not remove the clip, just swing it up.
If you have it in with the flats down and it does not seem to be aligned correctly do not undo the clip, just grab the electrical socket and move it into the correct position and you will feel it snap into its seat.
The drivers side is easier than the passenger side where there is hardly any room. Needle nose pliers with 45 degree ends are the best tool to use to pull the plug and to push and release the clip.
If you have fingers like Polish sausages you will have a real hard time.
