Re: HOW TO replace headlight bulb. Pictured step by step instructions
Musclefan mentioned not being able to put the spring back after taking it out rather than lifting it up out of the way. Here is a view of the spring and its mounting points.
Just put one end in place and flex the spring enough to insert the other end.
Yeah I know, easier said than done, use needle nose pliers and a mirror, if you are nervous about it springing away tie a thin piece of string or thread to it and tie the other end down.
