Old 10-26-2010, 11:46 AM
onehundred80
onehundred80 is offline
Default Re: How can I disable the TPMS? (Tire Pressure Monitoing System)
Originally Posted by rcompart
Easiest way to disable it is to remove the wire from pin 2 (red) and put it in pin 6 (blue). This will completely disable it and you will no longer have the light illuminate on the instrument cluster. This will not affect the HomeLink in any way so you don't lose that functionality.
To get at the TPMS/HomeLink connector, just remove the dome light and you can see the wires going into it. Remove the connector, use a pick or other fine tipped tool and depress the top of pin 2 so it will slide out. Push the pin back into the connector in the 6th position and reinstall the connector. Reinstall the dome light and you are finished.
Rudy, you are too smart.
Time to write a book and get paid for all this info.
How about
'Crossfires for Dummies'
or
'What Chrysler didn't tell anyone about Crossfires
or did not know themselves'?
PS
This is going to be very useful when the batteries in the TPM sensors go flat and people do not want to bother with the cost of new ones.
