Old 12-21-2010, 12:17 PM
oledoc2u
oledoc2u is offline
Default Re: DaMAGED CRANKSHAFT
spinning a rod bearing from lack of oil would be my first concern...second, I would do as the others suggested...a good machine shop will match the bearings to the crank, and won't be a problem at all...has nothing to do with HP...but getting oil to them is most important...plugged holes, bad oil pump, low oil level....need to figure that out first....good luck...
