Old 12-22-2010, 09:27 AM
oledoc2u
oledoc2u is offline
Default Re: DaMAGED CRANKSHAFT
Originally Posted by Rasim
I check the information with my work shop an d i was wrong not 2mm (1 mm per side) and just only 0.02mm per side that means all grinding took not more than 0.05mm
there you go....that is more like it.....they just cleaned it up a bit...you should be fine...but, what caused the failure to begin with?
