Re: Dead battery and key won't open door!
Okay, I got into the car by using Toolman's photo of the 2 bolts holding down the hood latch (thanks). You have to have a ratchet wrench or you could spend literally hours trying to do it otherwise. It took a couple of minutes and up comes the hood! After I put the charger to it I open and closed the driver door with the key with no problem. Anyway, I'm going to run a wire from the battery to just inside the front grille with an insulator cap on it. Then, if for some reason in the future I need to put juice to the car and can't lget the hood up, I'm all set!
