Re: Relay Replacement In RCM
To Start With, You Turn Switch And Nothing Happens,all The Dash Lights Are On And Horn Blows . So I Replace The Battery. This Didn't Help At All. Then I Checked Out The Rcm And Resoldered The Bad Joints And This Didn't Help Any. I Then Change The Batteries In The Key Fob And It Would Crank More Often But Would Shut Down In 2 Seconds. Inow Have Reprogramed Thefob And It Didn't Crank The First Couple Of Times And Then It Sarted Cranking And Ran Around 12 Minutes And Then Shut Down, I Did This A Few Times, But It Now Almost Cranks Everytime Time You Try.
