Thread: bas/esp light
Old 11-01-2011, 11:58 AM
zip439's Avatar
zip439
zip439 is offline
Default Re: bas/esp light
Originally Posted by kentucky gar
I have a 05 roadster ltd. Just put on 4 new Bridgestone Potenza re970as pole position tires. They were filled with nitrogen I have verified that the tire pressure is correct, I have tried the recommended reset but the BAS/ESP light stays on. I had someone check the OMB and it shows fault DTC code as B0001. Does anyone have suggestions? Does anyone know what the B0001 code is??
In the "Technical & Modifications" Forum you will find a master list of DTC. I just checked it, but no B0001 is listed. The B is for your body DTC, so Im wondering if you have the correct code? Please check the list for yourself it is a Sticky thread.
Hopefully someone with more knowledge than I can help.
