engine tapping
16
permalink
11-02-2011, 02:48 PM
onehundred80
Re: engine tapping
Hydraulic Valve Lifters
A device that eliminates the need for mechanical clearance in the valve train of internal combustion engines. Clearance is normally required to prevent the valve's being held open and destroyed as the valve train undergoes thermal expansion. However, clearance requires frequent adjustment and is responsible for much operating noise. The hydraulic
lifter
is a telescoping compression
strut
in the
linkage
between cam and valve, consisting of a
piston and cylinder
(see illustration). When no opening load exists, a weak spring moves the piston, extending the strut and eliminating any clearance. This action sucks oil into the cylinder past a check valve. The trapped oil transmits the valve-opening forces with little
deflection
. A slight
leakage
of oil during lift shortens the strut, assuring valve closure. The leakage oil is replaced as the spring again extends the strut at no load.
See also
Valve train
Positions of the hydraulic
valve lifter
, with engine valve (
a
) open and (
b
) closed. (
After W. H. Crouse, Automotive Mechanics, 5th ed., McGraw-Hill, 1965
Read more:
http://www.answers.com/topic/hydraulic-valve-lifter#ixzz1cYOOD6zF
Like
onehundred80
View Public Profile
Send a private message to onehundred80
Find all posts by onehundred80
