Re: shifter **** removal
There is a locking collar nut on the underside of where the **** and boot meet. If it is missing, that may be your problem. If you pull the boot over the **** you should be able to see the threads for this nut (the boot unattaches from the console piece by simply pulling gently) there are 4 tabs around the base of it. Hope this helps, I would NOT recommend glue because if you have issues down the road, you may not be able to properly service the car...
