2much2handle
. Also what does the 66.5 signify?
66.5 is the diameter in millimeters of the hub bore. For instance, if you were to find some OE Volkswagen wheels, even though they also use 5x112 they will not fit because VW uses a 57.1mm hub. So the wheel will not contact the rotor hat...
