Re: changing brake light bulb
Hey fun seekers......had to replace the back tail light on my alabaster white 05 roadster...logged on to the always useful forum, and found a posting somewhere that suggested you lower the top just to the position where the tonneau cover is vertical and the rest of the top is hovering above the seating area, then look inside and you can see and change the bulb without alll the agony of removing plugs and contorting yourself out of shape to get at it from the trunk........well I at first thought it silly, but I tried it and, guess what, it worked.....so want to thank that Crossfire guy or gal for the suggestion...........oh and someone added that you must complete your replacement within 20 minutes or the top hydraulics start to give out.....that happened to me but didn't create a problem, as soon as it started I put the top up and then lowered it to the above verbalized position, and finished the job.............way easy good luck to all you wonderbar Crossfire people Ron
