Re: battery drain
I had the same problem and wrote several threads about the subject. It is solved by 1) replacing the battery and 2) disconnecting the antitheft module in the trunk. Apparently, the antitheft device (below the foam matt in the trunk) was draining by working all the time. Just unplug the electrical harness goes to it, you find the difference in drainage. Good Luck
