Old 11-14-2013, 01:58 PM
onehundred80
onehundred80 is offline
Default Re: Possible SKREEM module.. cont. from another thread
Originally Posted by autumnmass
Hope you don't mind me coming in on your thread. I have a 2007 Chrysler roadster and it was experiencing no crank when turning the key. I did have all instrument lights, radio, headlights but car would not start. I had it towed to dealer today and he just told me it is the SKREEM module. I was thinking it was the CPS or Relay Control Module. They said it came up with code for SKREEM module. Does this make sense, they wanted $800 to fix. I hoping it is covered under my extended warranty. I never had symptoms of car starting and then dying out.
No crank is often the RCM problem, with the SKREEM problem the car cranks three times and then quits cranking until it is reset with a battery disconnect, it then repeats the cycle.
The RCM repair is cheaper, dealers often say the most expensive repair is required and then have you pay for the wrong repair and the correct repair. Which of course is even more expensive.
