Re: Possible SKREEM module.. cont. from another thread
Autumn, It may be that your RCM, as onehundred80 noted, could be the issue since there was no skreem like start up symptoms. The skreem issues will usually have those weird start up problems. To recreate them after the third attempt, as one hundred noted, just unplug the battery for a few minutes and reconnect and then try to start the car. If it indeed is a skreem problem, then the car will start 2x, die 2x, and then not crank. You could run over to the dealer and have them perform this check. It might at least put your mind to rest or save you money by avoiding a skreem module you might not need. Although a skreem module code does sound a bit indicative of a skreem problem and was present when I had a mine replaced both times.
