Old 11-15-2013, 11:50 AM
UK-SRT6's Avatar
UK-SRT6
UK-SRT6 is offline
Default Re: Possible SKREEM module.. cont. from another thread
This sounds so familiar to me!!! My SRT Roadster was off the road for 3 months while we tried to figure out the exact same problem you are talking about!!!
It turned out to be the Skreem module which cost me (here in UK) £1200
For your information, You CAN NOT replace the skreem with a second hand unit as it will not pair with the ecu, it has to be new!!! you can use second hand parts but you have to change the ecu, the skreem and the key barrel as a set from one car!!! You will need the correct set, there are two, one for manual and one for auto. They will not work if you try putting a system from an auto into a manual or the other way round.
Not saying your problem is 100% the skreem unit, just passing on my experiences with a very similar problem, hope it helps and good look.
