Old 12-06-2015, 11:07 AM
Adrian_X's Avatar
Adrian_X
Adrian_X is offline
Default Re: Passenger License plate light no power? Oh damn.
The water goes out of the drain holes in the bottom of the hatch door or the trunk lid on the roadster. If memory serves me correctly the rubber sticks out a little. The water will drain onto the area above the license plate and outside of the seal.
It certainly does not drain into the trunk.
Trivia question.
Can anyone say in what areas of the body is water that is originally on the outside of the car diverted through the body before exiting? Obviously the NA case mentioned above is one of them, so no points to be had there.
Yeah nobody said it drains into the trunk. It drains through the bottom of the trunk, aka the bottom of the trunk lid on either side of the trunk handle by the rubber grommets. Think you misunderstood my post.
