Re: WOW ... stop the rust while you can ...
Hey all, finally got the time and money to take care of my 04. I've been neglecting her for awhile, but after the RCM/CPS failed, I didn't have a choice.
After browsing around and seeing this thread, went out to pull the rubbers... and sure enough, the rust was bad. Only 50k miles.
Just posting to say, after I bit of research, I decided to:
1) Wire brush off what rust that I could
2) Clean the areas with 2 coats of Naval Jelly (you can find this at lowe's/home depot)
3) Apply 2 coats of Rust Bullet (had to order from amazon, the tiny can was more than enough)
4) Let it dry all day with fans before replacing the seals
Some tips:
Use proper protection (gloves, trash clothes, drop cloth) while painting the Rust Bullet. It does NOT come off skin for a long time, and it's permanent on everything else.
Have a wet rag ready in case you get any on the rest of the car.
I used the butt end of an old metal spoon to push the seals back in. It's not easy to do it right, especially on the corners.
