what temp does your car run at?
I was driving today and think my temp was too high, the gauge showed a needle width above center, but my DASh-PAC showed 210* and until today i was running at 198* checked and everything was full,no leaks ,, example about 3 monts ago it was 98* here in South F. and my car temp was 198* today it was 93 and my car temp shower 210.
amx1397-----210
amx1397-----210
on
Re: what temp does your car run at?
amx1397-----210
amx1397-----210
Mine is 100% stock and the needle runs mostly horizontal, sometimes slightly higher in traffic on hot days and slightly lower than horizontal running down the highway on a cooler day.
My temperature gauge needle is usually above the midway mark which equates to a dashdaq reading of 198 to 205º. Ambient is usually around 90º here. It has reached 210º going up the mountain but never at cruise or idle. The race track is another story.
Les
Les
Mine runs a needle above the middle line in weather above high 80's low 90's. When it is within the 70's it is at the middle or sometimes below.
I do have a super cooler on mine which does block the radiator some and im not running a tune or a different thermostat.
thanks for reminding me what is in front of the radiator ,,,,, I have NO heat exchanges on my car what i have is in front of the radiator one oil cooler 6" wide and 18: long and a transmission cooler 8"x 8" , maybe i should move them,, oh today at 4:30 pm i checked the temp of the street,,,,,,96degree asphalt and that is a street without much traffic . I just went out of my house walked took the temp of the street 9:33 pm------87 degrees jim
DITTO for both of mine...in 95 degree weather on a Dog Day Afternoon in the heat of August in Central Florida
I find it odd that on the Volvo sites there seems to be an obsession with removing things that block the air flow to the radiator of turbo charged cars while we seem more to fill up that space with horns, extra radiators and big K and N filters on DCAI systems.
I would at least like to move the horns out of the way.
On topic, on the hottest of days I run needle width above horizontal after a highway run.
Depends on my speed, slow 20x, if it is cooler out and Iam driving 50+ it drops to 19x with the stat. Our computer controls the fan speed, and i am working on a simple fan fix that is not programmed, so you can dial in the speed MINIMUM and thus set the MINIMUM airflow to better cool the water and MOTOR.
The time is just the issue witht he fall being here and lots to do........wdy
cool green !!!!
cool green !!!!
cool green !!!!
cool green !!!!
Meanberg
06-14-2015 02:25 PM
gobraves423
06-06-2015 07:03 PM
blackpepper
16
06-02-2015 12:50 PM
