starting issue
starting issue
I have an 04 crossfire with 80000 km on it. it was running perfectly until recently. Sometimes it wont start. it turns over and acts normal but wont fire. I can hear the fuel pump and I wait till it stops. ive replaced the cam sensor the crankshaft sensor and the fuel pump relay but it remains the same. if I keep trying it will start and when its running it runs perfect and has never stalled... Any ideas? very frustrated
Re: starting issue
well . i put a bosch crank sensor in. no difference..took it back they replaced it. still the same...I have tons of juice it turns over very well. it will make a backfire noise if I keep cranking it..so I think I have lots of fuel.. ive changed the fuel pump relay and I can see it closing properly.. maybe cam sensor wire...any other ideas anyone?
Re: starting issue
Possibly an injector that is leaking? Have you tried to "prime" the engine by turning the key to on (not start), wait about 3 seconds, back to off and repeat twice and then crank?
I had a leaky injector in a Thunderbird that caused a similar symptom unless I primed the fuel system. Basically the pump could not build pressure quick enough and add to it that one cylinder was flooded it wouldn't want to start for about 10 seconds of cranking.
Only other thing that comes to mind would be a faulty mass air flow sensor, but I have never had one not allow a car to start, just stay running was the issue. I have never seen one that did not throw a code almost instantly as well.
Good luck, hope you find the problem.
Re: starting issue
I replaced the rcm and I can see that it is closing. the strange thing is that there is no codes. I can hear the fuel pump and I wait till its stopped and then turn it. sometimes it starts .sometimes it doesn't. it has never completely stranded me but its embarrassing. if it threw a code at least I would have a starting point. if it was the ignition I don't think the points would close. I think it must be a wire.. crankcase wire possibly. it is possible that I have 4 faulty crank sensors but really..i think if it was a maf problem it would also affect driving ,. but I will look at that too. I think it would throw a code .
Re: starting issue
Yep, you are looking for 50-60 PSI at the test port.
You can probably save yourself a bunch of $$$ by testing it yourself.
Not entirely certain this will connect properly, but for $30 it's worth a shot :
Re: starting issue
I believe I have found the culprit.. wasn't fuel. its the wiring to the crankshaft position sensor..since it only failed once in a while it was hard to figure out but while it was running I just touched the wires and the car shut right down..could have been bad if id hit a pothole..
RESHOE (06-15-2021)
Re: starting i left out answer to lead quesrion.
on
I'm having the same exact problem with an 06 crossfire limited, not the supercharged model. My car has 9,200 original miles on it and when I had sat in the car idling for about ten minutes it died like it ran out of gas. It would crank over like mad but wouldnt start or stay running without dusting it with starting fluid and then it would run great for about 5vseconds then die out again. I believe I'm having a fuel problem. I changed out battery with a high cca rated battery and replaced the crank and camshaft sensors. I Al's put a new fuel pump and German fuel filter. Any ideas? By the way the connectors are online with napa I believe.
THis is the kit I bought, for under $40, it tests the Crossfire and my Ford Ranger - as easily as checking a tire pressure:
https://www.summitracing.com/parts/otc-5630
Beyond that, I'm thinking MAF or Throttle Body.
Re: starting issue
Last week it was found that my fuel rail was losing pressure. Cranked for a long time before start. Went from 60 pounds to 15 as soon as the engine shut down. The repair shop said it was the check valve in the new pump they put in 7 months ago. Replaced the pump under warranty. I've read in a few places in this forum where folks said the filter check valve kept the pressure in the fuel rail, but if so why did the shop replace the pump? They didn't replace the filter. The problem is fixed.
