Crossfire differential?
Re: Crossfire differential?
Brought my oil to an oil change place as I usually. Get it changed with my own oil and filter.
Guy comes up to me with black sludge on fingers saying my differential oil needed changing. I said this car has a sealed differential doesn't it? He said no. I said bo, I'll pass .
Was I being conned?
Was I being conned?
Was I being conned?
Was I being conned?
(But) "black smudge" on the fingers could be part of some kind of con job. Maybe do it yourself or take it somewhere else.
Natesnyder (03-08-2021)
as stated above your differential is set up like any and all rear wheel drive vehicle . your diff is kinda sealed ,it has a breather and it uses 90-140 gear oil, it is a open rear . but use a good oil, your oil should be black, but not sludge. most of the time the rear gear oil will last 10 to 15 years well over 100,000 miles ( if u have a wave-trac limited slip unit then order oil from needswings . only a few oils work with the wave-trac.
take it to a shop , and ask them to check the differential oil and you want to see them do it because you were told it is full of sludge they will let u see it done.
Yes; do it. Motul Gear 300 75w90 100% synthetic would be a good choice.
I haven't used it, but Lucas Oil is another great brand, and is no doubt another good choice for synthetic gear oil.
on
If you like Lucas, then this is the recommended rear diff gear lube....
Synthetic SAE 75W-90 Gear Oil
(FYI: I used Amsoil 75W-90 Long Life Synthetic Gear Lube in my N/A Limited rear diff)
amx1397
11-23-2019 09:13 PM
snpiee
02-09-2016 12:04 AM
Padgett
12-31-2015 09:59 AM
TexasSRT
11-02-2015 11:45 PM
