PDA
View Full Version : Crossfire Coupe
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58
  1. driving a lean-to...
  2. mystery sound in my coupe's behind
  3. Clear coat failure around the windshield
  4. abs wiring harness
  5. The black is back!!!
  6. unhappy first time
  7. A/C stopped working. Where to start diagnosing?
  8. Eurocharged Father's Day 2017 -- Take 15% off Tunes!
  9. Is this some special edition coupe?
  10. New Member/Buyer Good Deal?
  11. Just bought crossfire and could use some help with a few issues
  12. the leak was in the flexable grommet tube that connects the electrical and the yellow
  13. RPO codes or sales codes
  14. Uk park suppliers or breakers
  15. Eurocharged ECU Tune or Sprint Booster?
  16. Eurocharged ALL Crossfires May Sale
  17. Need some opinions if this '04 crossfire is worth buying.
  18. Intake manifold cleaning.
  19. Spoiler retracts at 60 MPH
  20. Side mirror can't be adjusted
  21. Recommended wheel replacement
  22. Back from the dead.
  23. hole in rear body
  24. crossfire project black grey
  25. Rear drive shaft/U-joint
  26. CROSSFIRE lettering for Trunk
  27. Engine making strange noise?
  28. crossfire battery problem please help!!!
  29. Park/Neutral Position Switch P0705
  30. Eurocharged ECU/TCU tune sales!
  31. 2006 Base X-fire Flywheel is Toast
  32. 4 channel amp
  33. Anyone tried two different tire pairs?
  34. Weird Strong Burning Smell Occurring!
  35. High pitched electric motor noise from rear
  36. Windshield pillar
  37. Odometer Issue-Miles randomly jumped?
  38. Tire Rack vs Costco
  39. How to get more HP?
  40. '05 with Rebulit Title
  41. the black box question
  42. Transmission problem
  43. Base M112 E32 Engine (Turbo Project Early stages)
  44. Won't start - very randomly
  45. LED vs HID
  46. Improve mileage
  47. Mystery No Start, Same Symptom - New Problem??
  48. Buying a dead car
  49. Buzzing noise
  50. Sun Visor Mirror
  51. Trunk lid lifts
  52. What's this hose and help with a leak
  53. P0410 Question...
  54. Interstate Battery - Tight Fit
  55. Bump in the trunk. Annoying rattle
  56. Wtf 2
  57. xFire Limited sound system.
  58. Sticky Ignition Fix
  59. Wtf
  60. Tyres
  61. High RPM bucking, hesitation
  62. 2005 Crossfire suddenly died while driving?
  63. Right Upper Control Arm
  64. Battery dead
  65. Found a Startech Spoiler for you
  66. For sale 2004 Crossfire coupe
  67. Club
  68. Mileage
  69. Help!! RCM trouble!!
  70. How does it call this tube and can i order online ?
  71. OEM tires
  72. 2004 Crossfire no cranking but fan running
  73. No key for locking lug bolt
  74. Water in the trunk/hatch
  75. Screaming Hi-Rev Start-up
  76. Wondering about wheels
  77. Keyless Entry Alert Passenger Side Lights Only Flash
  78. Original Air Filters and Cabin Filters In Vehicle ? ? ?
  79. After market radio power but no sound.
  80. Warning Lights
  81. Does anyone have a way to fill in the hold left from my cupholder?
  82. "High Heat" light comes on
  83. Sticky Key got me...
  84. Air Bag Light Stays On
  85. no start
  86. New Stereo Philips CED 781
  87. The bell tolls for thee Crossfire...
  88. dreaded spoiler
  89. cooling fan runs constantly, a/c blows warm.
  90. Will the Crossfire increase in value?
  91. Flashing fog lights
  92. Storage nets behind seats
  93. lost grommet where to buy one
  94. Key fob replacement case...
  95. Replacing Varta batteries in alarm siren..
  96. Paint help please!!!
  97. Arlington or DFW Mechanic Needed
  98. FCP Euro OEM Parts Index
  99. Tpms
  100. Vinyl Wall Decal - 25" x 35"
  101. Any ideas?
  102. crossfire luggage set?
  103. all weather rubber floormats
  104. Toll Pass
  105. Care tips?
  106. Valve cover
  107. belly pan hardware
  108. Need fix Steering locked and key locked in ignition
  109. AC/Heat
  110. Electric DIVERS SEAT
  111. Eurocharged
  112. Manual drivers seat adjustment...
  113. Surfboard & crossfire ?
  114. Crossie For Sale
  115. Selling 2005 Coupe Limited
  116. Thanks forum members
  117. Rear sway bar mount broken
  118. '04 Crossfire Coupe Battery Slow Drain
  119. Bosch 9600 FR8KII33X
  120. Bas esp light on - then gear indicator window goes dark
  121. And end of an era.
  122. Valve Cover Bolts at NeedsWings
  123. Chrome Door Handle Covers
  124. Wheel Alignment Woes
  125. Left fog lamp
  126. Interior plastic crack.
  127. Car won't start check engine light is on but I have replaced the RCM
  128. Buying a new coupe limited
  129. MB engine and chassis
  130. Mercedes / Chrysler Parts Cross Referencing
  131. What IS this part?
  132. '05 no start
  133. Is this car "worth anything"
  134. Sulphur Smell
  135. 30,000 Mile Wheel Cleaning
  136. Chrome bumpers
  137. Battery light on - electronical issues. Please help!
  138. help guys?
  139. Help!!
  140. Sticky Gear Shift
  141. Manuel gear oil
  142. Noisy spoiler operation
  143. SRT Front Spoiler
  144. Much better IMO
  145. A couple more small modifications (rear light tint and door handle respray)
  146. Wheel refurb and AMG C32 brake upgrade
  147. Can you fit 4 x 19" wheels without tyres in a coupe?
  148. Transmission Fluid Leak w/ pictures
  149. Stick shift handle
  150. Help - occasional uneven idle
  151. Coolant Reservoir?
  152. highest possible gloss wax
  153. Thinking about buying a Crossfire!
  154. ugh, oil everywhere
  155. Popped into work to carry out a few little jobs
  156. Panic Button Keyless Door Lock
  157. when the defrost is on the radio gets static
  158. Radio upgrade Kenwood KMR-D558bt or D562bt ?
  159. Radio Upgrade Kenwood KMR-D588bt or D56bt ?
  160. 2004 Crossfire coupe limited
  161. 16-Year-Old Crashed Mom's Crossfire On Nürburgring While She Waited In Parking Lot
  162. switch for closing spoiler stuck!
  163. Transmission Vibration in low gears
  164. Left signal lamp
  165. Veteran's Day Sale!
  166. question about lights
  167. right indictator issue
  168. No BRAKE LIGHTS - BAS/ESP signs on the dash + LIGHTS when I hit brake light
  169. Airbag Light Indicator
  170. Base or Limited
  171. Trans Connector Socket Leaking Again
  172. Reasonably Priced Cold Air Indution?
  173. Thyst grow up so fast...
  174. Adding lights in foglamp spaces on base model
  175. Are all rear spoilers the same size for the coupe base?
  176. cup holder
  177. Picked up my '05 Crossfire 19k miles over the weekend...pics!
  178. Tire pressure
  179. Someone please help me with this noise coming from my car
  180. Airbag light on
  181. '04 Crossfire Ring in Bay...
  182. Big thank you crossfireforum !
  183. Should I Turbo?
  184. o2 Sensors
  185. Just put a deposit on an '05 Crossfire with 19k!
  186. Headliner Replacement Repair - ABQ, NM
  187. Crackling noise under windshield wiper vent
  188. Side indicator cover
  189. New Owner - Front parking sensors
  190. Touch up...
  191. Bluetooth Hands free options ?
  192. New Paint
  193. My Journey to Crossfire Ownership
  194. Muffler delete question
  195. tinking in motor till car warms up completely Chrysler Crossfire
  196. Want to swap interior dome lights with white LED...
  197. brake replacement
  198. Need "NEW" Center Mount Brake Light - Anyone know where to buy one???
  199. White Smoke after 87 OCTANE??
  200. How loud is the interior of your Crossfire?
  201. Double Din standard kit project: Survey
  202. Lower control arm
  203. tires for crossfire
  204. 2004 crossfire jumps to 5 rpm while driving in automatic suddenly
  205. Exterior bulb light
  206. New Owner With A Few Questions
  207. Muffler Delete Videos
  208. Key fob reprogramming confusion - help!
  209. Number 23 on the list
  210. Sticky Key help please
  211. Does everyone actually use Mobil1 0W-40?
  212. Totaled D:
  213. Rear, single bleed screw?
  214. Rcm solder repair question
  215. adjust the spindle nut.
  216. Need some help
  217. Not starting
  218. Confused about headlights...please set me straight
  219. Steering pump reservoir leak
  220. HELP! My Crossie is turning into Christine
  221. Personalized plates - I got mine!
  222. Transmission converter control solenoid
  223. "Chirp" for door locking?
  224. Question about eurocharge tune?
  225. Sloopy Steering wheel. HELP
  226. Crossfire next door
  227. spoiler board paint problem
  228. Car won't start
  229. Weatherstrip: Left Door Belt Moulding
  230. 2004 Crossfire for Sale only 35,861 miles!
  231. some XF's for sale in my area.
  232. Noise from Rear Hatch Area
  233. One bright taillight, one dim
  234. down shifting to passing
  235. Bosch Iridium Gap
  236. manual tranny
  237. 100k Tune Up?
  238. Are you kidding me??! Flyer went INSIDE my door.
  239. Factory factory tinted windows cost me a ticket.
  240. Painting machined exterior trim pieces
  241. Cabin Air Filter
  242. Headlamps - high beam vs. low beam
  243. Need help
  244. Lift Pads
  245. Hi I'm new to forum. So hello all !
  246. Need help to post pic's
  247. My Luck
  248. Key will not turn in the ignition.
  249. Brake Caliper Covers?
  250. dash kit/radio deck combinations?
