View Full Version : Crossfire Coupe
- Quick Wheel Spacer question
- Seat roll bar hoops in a coupe?
- Total loss
- 6 speed manual, 40,000mile uk coupe for sale
- 06 limited ON B A T right now
- 2004 Crossfire Coupe For Sale
- IS it worth upgrading from N/A to SRT6?
- Fat Guys in Crossfires
- Which Scan Tool for FLOOD car Repair
- Buying a 2004 crossfire
- Wilma
- Let’s talk ECU and TCU tuning
- Back Glass
- Broken key
- Best Waterproof Cover??? Help!
- Hemming’s New Listing
- New Seats
- Replacement top DIY or installer
- Aluminum Valve cover aluminum screw extraction
- Torque Pro App or apps alike useful for what?
- Real Brabus/Startech build
- DCAI install and relocating coolant/power steering lines?
- New Headliner
- 2004 crossfire coupe brakes
- Scanned Fault Codes - p2312 & p2404
- Crank but no start
- 2004 Crossfire DIED ON THE ROAD +Other
- Going to look at a 04 manual with 105k
- Break pedal problems
- 2005 crossfire odometer roll for?
- Transmission fluid!!!
- Central locking hell
- General Fault Finding
- Cabin moisture on carpet at the rear of seat floor after heavy rain?
- Hood release lever broken - replacement
- Crossfire Test drive and Price Help
- Crossfire Mileage/Kilometer Help
- 2007 Crossfire: Seeking Airbag Module
- Is a 04 XF with 26,000 miles worth it? Seller is asking 9.5k
- Acellerator Woez
- Where to buy rear window for 2007 coupe.
- Help with Sticky Key Lockup
- Remote woez
- Is it an '04 or '05 Xfire?
- Tirez
- How to lock hatch ?
- '05 xfire now a rescue vehicle!
- Some Crossfire Parts For Sale
- Towing
- I need a coupe in the Detroit area. (Ferndale)
- What causes a Crankshaft Position Sensor to fail?
- Help finding an '04 *programmed* TCM
- odd gearbox problem
- New Crossfire in Las Vegas
- 14 years...
- When I press key fob to lock doors my flashers come on
- Weird idle
- Double Din Aoz parts kit??
- Spoiler came up for no reason
- Cleaning Out The Garage...
- DIY Oil Change - Over 1 Quart left in the engine?
- Driver side AC issue
- Running starting and running problems the car will start twice and run for 2 seconds
- Water window drip guard
- 2004 Graphite MA vs 2005 SRT6 paint
- Newest XF in USA ?
- Fuel System???
- How safe are our cars from theft?
- Preventing Chrysler emblems from fading
- 1.5-2” Lowered suspension from previous owner causing cupping.
- Instructions on how to replace alarm siren
- SRT6 or Crossfire merchandise
- Prevent the Chrysler emblem from fading
- Xfire literature
- Stolen in Massachusetts on 6/3/22
- 2005 xf thumps loudly an dies
- Couple quirks...heated seat light working intermittently and airbag deactivated
- Don't start, don't lock unlock door, fun run without key
- Replace Chrysler emblem front and back
- This is probably a dumb question but what electrical part am I looking at?
- Oil cap HOUSING seal
- Headliner not attached by black screw clips in the back of my car?
- Alarm not working
- How to open fuel door manually as security system wont open it?
- Clutch replacement
- Need exact measurement of dash width.
- Wind noise and clunky door
- Need: Steering Wheel emblem
- Door lock/unlocked stopped working
- Please help - water leak
- Again...how to secure the beige trunk panel
- Trunk plastic fasteners where to buy?
- Code 581??
- Help needed
- used crossfire concerns
- New Sprint Booster vs Old Sprint Booster
- Using a crossfire as a daily driver, thoughts? Concerns?
- Any good mechanics in or near Columbus, Ohio?
- Emblem
- just picked one up
- video in case you wana see it
- 2004 XF service manual
- Need to find driver side motor mounts
- Seafoam Top Engine Cleaner???
- Where to buy Driver side catalyst converter
- Brushed aluminum dash kit or dash kits in general
- A little help…
- What is this panel called?
- Water leak through the quarter glass
- 2006 Coupe mods. Loving this thing!!
- Spoiler painted - now won't retract all the way
- $36 Rubber Floor Mats on Amazon
- Blackstone Labs Oil Analysis Results!
- 15th TotD Preparations
- Anybody know what this is?
- Found a decent price on a camshaft position sensor $48.90
- Infamous "Crayon" smell...
- Rear stabilizer mounts
- Check your rear bumper corner panels!!
- Hello, new Crossfire owner, make sure to check your air box!
- Remote starter switch
- Headlights!!! Aftermarket???
- Limited decal???
- Crank Issues, Shift Issues
- Sell the low mileage '04 Coupe? Keep it?
- Alternative cold air intake
- Double din kit
- Ac question
- Key fob
- Coupe value going up soon??
- Help!! Need advice
- Removing CROSSFIRE emblem??? Chime in!
- Need help with new shift knob options
- Door/window seals and air noise…
- Wheel well spacing??
- Never knew there are hidden change slots...
- Window washer reservoir
- Hood shock 2004
- Dashboard lights
- Key Fob not unlocking doors - need troubleshooting steps
- Passenger Side Front Turn Signal Marker
- Touch up paint??? Oyster Gold.
- Finally picked it up! Clean!!!
- Windshield Sunshade for Crossfire that fits pretty good
- Radiator Fan Replacement
- Any info on this crossfire build?
- AC problem
- Wheel well
- A/C compressor
- Screen Modular
- Windshield trim refinish
- Oil leaking from right side of engine. Think it's valave cover gasket.
- Knobs for ac control
- Engine coolant specification
- 2005 crossfire coupe headlight
- Good Article
- Looking for a louder exhausted. 2006 Chrysler Crossfire Base
- starting issues
- Need help finding cold air intake. 2006 Chrysler Crossfire Base coupe
- Seat height
- Rear Wing/Spoiler Installation
- I need help. 2006 Chrysler Crossfire Base coupe
- Suggestions on a camber kit?
- Suggestions km
- Alot of misc queations, need your guys help.
- FSBO-2007 Coupe, MT6, machine gray
- DIY intake info
- TVT designs
- Cargo Cover
- Oil suggestions for 150k miles?
- Buying a Crossfire. HELP!!
- I can’t open my boot.
- Vehicle Jacking Points
- Engine enhancer in a bottle! (2006 CF)
- My $500.00 Crossfire
- P0444 with Check Engine Light
- Clunking sound right front
- Wiper Drain Tubes
- Left turn signal indication quit.
- Fan resistor bank goes bad...a little scary!
- Windshield trim
- No luck but bad luck! Starting problem.
- Hatch lift supports and Alarm batteries.
- '06 crossfire steering wheel removal.
- Foglight Replacement
- Best place to put a floor jack!
- Replacement Side markers
- Radio blues!
- Control Box for the Locks has Been Wet / Help Please !
- Looking for a mechanic or shop in Chicago or Illinois to fix crossfire.
- Strange jacking observation!
- Crossfire hacks to make it mine!
- Slasher Stripes
- Grill Mod to allow better flow
- Pentosin 1405116 CHF 11S Synthetic Hydraulic Fluid on sale for 13.00 !
- 2007 Oyster Gold Coupe / 1rst time for that color!
- Needwings SL55 Dual intake setup on my SRT-6?
- Wheel Size
- Supercharger on my SRT-6 not working / Where to start in Service Manual?
- Door Handle Covers / What else uses the XF handle?
- AMG Rims on a SRT-6 Staggered But . . .1 thing
- Some Buying Advice Please
- Loose trunk letters
- replacing the hatch lift support
- Spoiler issues/seats don't work/ A/C cooling issues / Damaged piece behind the seats
- Specific production numbers
- The ghost in the machine resides in my 2007 Crossfire.
- Misleading Misfire Codes?
- Remove windshield wipers
- Non-Structural engine/body braces
- Crossfire StopTech 127.35058R Sport Drilled/Slotted Brake Rotors (Left & Right)
- Car parts needed
- Driver side brake light go off when apply brakes
- Tire fix it
- Battery light on on04 crossfire coupe
- Plastic Rivets
- Cover Suggestion
- Starts only on second try but has more issues
- Rear Camera
- Are Touch=Up Paints ALL the SAME? Dupi-C0L0R?
- Location of blower motor ??
- Wings UP and FLASHING SWITCH ! SEARCHED BUT NEED HELP
- A/C not blowing ice cold air
- Supermile Gated Manual?
- Cig lighter DOA ! Steps to finding power? 1 2 3 ?
- Clean AC drain possible??
- Custom letters in Crossfire font?
- N/A Tune
- Rear Deck Emblem
- Under dash screws 04 coupe
- This Beeping noise is driving me CRAZY
- 2004 engine "knock"
- Help - Need to Replace Alarm Siren
- V8 Swap UK?
- 2006 40K service advice
- Crossfire 2007 Coupe (sensors) Paint Code
- Crossfire (Kit Car) - Track car build
- '03 coupe - Won't start. Help Needed
- No sound from fuel pump and 04 Crossfire Coupe not crank
- A few question from a first time owner.
- Replacement Crossfire Floor Mats
- Buying replacement steering wheel
- '04 - Dead Battery - Speakers out - Not fuses or amplifier?
- '04 Crossfire Coupe. How to check third brake light?
- Crossfire key replacement
- No start cracks 3 times fuse 37 keeps blowing out
- Water coming in passenger side crossfire coupe
- '04 coupe brake light go off on drivers side when you apply brakes
- Push to start
- 2004 Chrysler Crossfire will not turn over
