View Full Version : Crossfire Roadster
Pages :
1]
16
17
- Mercedes tips and tricks
- Enjoying the Sunshine.....
- 1c3an65l75x037691
- Top seam separation
- No Brakes
- Instructions: Replace BAS Convertible Top
- 2008 Service Manual - TOP SECTION
- Convertible Top Not Working
- Top cylinder clips
- Wanting a bad power top control module PTCM
- Rear top bow on the loose?
- Top sensor plunger
- Mesh wind blocker vs plexiglass
- PSA carry a spare RCM
- North East PA - Convertible Top Replacement
- Passenger break light won’t shut off
- Convertible top rubber seals
- Top wont open/close - back wont raise high enough
- Cargo liner fastner
- My Journey with my 2006 Roadster "Svengoolie"
- 2005 roadster top hydraulics
- Sticky Key Fix didn't work, what now?
- Roof leak??
- New Composite Hard Top
- Top Hydraulics - pump rebuild
- OEM top tool
- Top inoperable - module?
- BAS Top to tight
- 2006 Roadster owner's manual identification
- Please help with my top problem
- If you don't want to lose your Tonneau flap covers
- Three 2007 Roadster questions
- Triple pillar gauges for crossfire roadster
- Back window re-glue needed
- Hood Noise
- A happy customer from BAS Convertible tops
- I should be alarmed???
- Driving In The Winter, What To Keep In Mind?
- topsonline wear pads
- Convertable top Divider Switch Question
- How to replace left rear brake light?
- 2008 Service manual Top section
- Tonneau lid sensor
- How to replace D-ring that pulls down top?
- Hydraulic roof lift cylinders mounting clips
- Top color
- divider microswitch
- 2008 Oyster Gold roadster 6 speed
- Rear Window Glue Up
- BAS top window trouble
- Manual / Emergency Top Tool
- Top Won't Latch
- Convertible top repair cost
- Looking for a Great Car Cover for the XF
- 3d printed top open switch cam/plunger
- Looking for first CF
- Any roadster top help welcome?
- Moisture problem in the right headlight
- Crossfire Roadster grille available in Cowtown
- Trunk fix
- Rear Deck Black Top Strip
- closing top caused mirror to break off.
- Passenger side seat will not move front or back .
- Great Crossfire Resource in FLA
- Top won't go up?
- 05 Roadster Top Stopped Working Without Warning
- Top Open Switch
- Tonneau cover will not budge! BAS/ESP light on after battery change
- Battery won’t hold charge
- Convertible frame parts
- Windshield surround finish, 2005 roadster limited
- New top 06 roadster limited
- Trunk safety release broken ?
- 2008 Top Service Manual Extract
- Flap on Convertible Cover Adjustment
- Crossfire duffle bag!!!
- Is there a way to manually release, open trunk?!
- To buy or not to buy...
- Performance chips
- Wife vs Convertible Top
- 2007 Crossfire Special Edition in Tampa, FL
- UK Roadster Thread - drilling into the trunk
- Crossfire flap cables
- Trunk (Boot in UK) locked.
- Trunk Bump Stops
- Top replaced ??
- Air Bag Module
- Need Trunk Divider Switch
- Convertible Top
- Top will not go down
- Replacing Soft Top
- 3pc Custom Fitted Luggage Bags for Chrysler Crossfire
- SRT-6 Roadster production numbers
- Rear suspension arms both sides
- Roadster VS Convertible/Cabriolet
- Broken trim piece
- Rattling/Knocking sound from driver side rear wheel
- Door Edge protectors
- Rooftop closing procedure
- Trunk Dimensions Roadster
- Roadster top maintenance???
- Trim
- Centre armrest won’t open
- Was there a cap?
- DIY hydraulic cylinder removal
- Top, and trunk light issues
- 2005 crossfire
- New Convertible Top cost
- How tight is a crossfire
- bring a trailer '08 $20,000 ends in 4 hours
- Factory audio amp
- parts equivalence
- Cabriolet Hydraulics in Sarasota, Florida
- Convertible top hydraulics maintenance
- convertible side flap bracket
- Top release handle.
- CABLE. Tonneau Side Flap.
- Gearbox oil help
- Tips for 1st time convertible owner
- Bizarre Electrical Problem
- Care for the top and washing
- Convertable top cable
- Damm heatshield
- Convertible top glass
- How to treat the rubber seal behind the convertible top
- Yellow trunk release stuck and hanging off
- Strange combo of symptoms
- Location of Crossfire letters on trunk lid
- Latch Retainer Switch
- Convertible Trunk Divider
- Keep or Pitch old top?
- New Owner - Hood Issues
- Bypassing the Divider Switch ("sensor")
- abs repair
- Automatic Top issues
- Throttle body
- Code P0175?
- BAS International Convertible Tops
- Seeking help with top measurements
- Trunk light fuse
- At a "crossroad" with parts needed to fix top
- Pull handle on drivers door.
- Fixed non-operating top & spoiler with $2 switch, thanks to this forum
- top windows don't go down after unlatching top
- Minimum Tool Kit
- Total number of srt-6 roadster. In triple BLACK
- Roadster trunk light?
- Inoperable Top in Minnesota
- Transmission issues
- '05 Roadster Purchase 83K
- BAT Auction
- Weather seal?
- Transmission Fluid surprise
- Spare Tire that Fits in a Roadster
- 05 Crossfire factory radio connection by harness?
- Convertible Top Operation and the Central Locking Pump
- No power to convertible top hydraulic pump
- Convertible Top Microswitch
- Question for current owners
- Hood repair
- Central locking pump
- Rust proof undercoating ?
- What are these conceals called and are they available?
- Rear Window Insurance Claim
- Small lights in headlight housing
- Testing Water Selling Wind Deflector
- Installing a new top on my '07 Roadster
- Glove box switch
- Needswings cold air wrapped a the way to the front grill?
- 2005 Crossfire SRT-6 Roadster Tire size
- Cable tonneau flap side wanted...
- New member question and hello
- Tale of a Crossfire Roadster
- 2006 Gray Roadster VIN 1C3AN65L56X068620
- All weather floor mats
- Roof - Top indicator Blink
- Inside headlight
- Rear sway bar bushing
- Rear window falling out?
- Diamond Jubilee on FB
- transmission fluid exchange
- No start, battery 12 v, spoiler not up
- Convertible hydraulic strut
- Mayday! Need Convertible Top Control Module!!!
- Replaced all hydraulic now top not working
- Crossfire batman car at matthewsons
- Convertible window repair
- anyone in/around central ny that has replaced a top?
- Looking at a 2005
- Convertible top probllems
- Ac condenser fan?
- Spoiler up, CC not working, traction not working
- Convertible top function
- The rear window thing again!
- How do you carry snow skis in this thing?
- repair work
- 10K Cherry
- Convertible Top won't go down - first try of the season?
- Decklid won’t open
- Belt tensioner bolts2005 Crossfire convertible
- cable source for side flaps $59 a pair
- black convertible top restorer
- Sun shade?
- Top repairs
- Remote key failure
- Issue with flaps - Help !!!!
- Alarm when manually operating top?
- Wrinkles in convertible top
- Best front brake pads
- Purchase of 2005 Roadster Advice
- wheel size
- New Old Stock Windscreen 82209107AB
- Convertible top rear latch not working
- Mystery Rubber Bumper
- Rcm problem?
- Replacing cylinders & top
- Spoiler problem
- Cover manual access?
- Sooo...any tips to get the rear weather stripping back on when changing the top?
- Bosch 1100 no codes
- help with convertible operation please
- Roof not working
- https://www.ebay.com/itm/1-43-Norev-Chrysler-Crossfire-Roadster-940005/193888713987?_
- What electronics are under passenger seat
- Top and spoiler not working
- windshield trim
- Crossfire center console with Convertible Roof Control Switch
- Moving from New Member thread - IT LIVES!!!
- What else should I check before ordering a replacement Header Latch Switch?
- Roof spare part problem
- Trunk Bracket Divider - Cheep fix
- BAS Group buy
- Issues of which I need to be aware?
- Automatic question
- Lost - hydraulic pump reservoir plug. Replacement?
- Hydraulic leak on roadster
- battery drain
- Roadster Undercarriage (Not Mine)
- Roadster roof won’t finalize
- My top is falling down
- Twill Fabric Protectant
- Group buy - BAS Tops
- Convertible Top Module
- BAS group buy...
- Black Car with red top
- Srt6 spoiler on N/A
- valve cover gasket
- Spring in the trunk lid
