- Running wires for aftermarket amp and rear speakers ('05 Base)
- Oil change
- Radioshack Piezo Buzzer
- Car dies
- unplugging amplifer
- SRT6 Rear End Removal - Short Cuts?
- N/A Spoiler Removal Guide
- Hood liner sagging ... need suggestions
- How to replace the alarm siren?
- +1 Blown Rear End - Now What?
- Transmission fluid down 2+ quarts ???
- Index of Crossfire problems and repairs
- Cyclic Drill Noise At Idle... ???
- Tranny fluid ? Need some advice ...
- Auto roll up windows with remote?
- oil leak
- Click Click From Throttle Body???
- Convertible top WON'T CLOSE!
- Anyone Tell Me How To Replace My Brake Pads
- N/A 74mm Throttle Body Upgrade Guide
- Remove mounting bolt covers?
- Ready to install DCAI
- Need help - compression test?
- codes
- starting car - dies immediately - horn on
- Crossfire Service Manual Set
- Air Con Service
- Cabin Air Filter Replacement Procedure Narrative
- Plastic Headlight covers
- How do you remove the steering wheel?
- Horn All the Time revisited
- trunk rattle
- Jump your battery with aspirin?
- Headlight adjustment
- Thank you
- Strange seatbelt warning
- Cooling system pressurized or not?
- Relay Replacement In RCM
- flush and change engine coolant
- Help! bas esp light on and check engine light
- Roadster with leaky roof. Anyone have a fix?
- I need a step by step zietronix how to
- Windshield Washer Nozzle Cleaning
- Mechanic in Pensacola
- Silly question about OBD2 port
- HowTo properly gap precious metal spark plugs
- Help! Crossfire stalling problem
- Motorkote
- Assistance please on a 'how-to'...
- Conversion of Electronic Display to Metric
- Side Mirrors Switch 2005 Limited
- Help Ignition issue
- TVT300 Installation how-to
- Recommended Mechanics
- reseting reminder when oil changed
- Does anyone know how to remove electrical connectors from ecm
- Oil Level Sensor
- upgrading seats?
- How to remove fender strakes and wing logo
- Another battery question...
- battery replacement
- How lower xf the correct way?
- Start Enable not Sent (Error 2071)
- Site for Recalls for Crossfire
- "Body control module" failure
- NOTICE: Loaner RCM now available!
- How To Replace Plug Adapter On Trans
- Supercharger Oil Change
- airbag module location
- Great DIY Cup Holder Mod
- Crossfire Drift car
- conv top hydraulic system bleeding procedure
- Wiper Arm
- Convertible top won't go down
- Nitrous N/A
- Xfire won't "stay alive"
- Technical Information Database
- Key broken in tumbler...what to do
- Rear Window Fix
- Transponder ring wiring
- A word of thanks for the how-tos
- Is this oil OK?
- TSB Work
- intermittent no power when key turned
- My 'Other' Cup Holder Mod!
- Throttle Body
- auto transmission slow going into first
- enclosed car hauler?
- need code list
- The quest for a "perfect" crossfire, need help with my "TSB's"
- AT Tranny stuck in gear
- Moisture in Headlight
- Why can't we put a hitch on our car?
- Can't get in to my car :(
- at stop... lights dim, and engine whines...
- Brake replacement???
- Engine light...
- How to remove door panel
- Power Locks Need Help Asap
- Ethanol (Rather Lengthy Verging on Boring)
- How To - Transmission Filter/Fluid Replace
- Double Wrench Service
- Key Fob
- How to replace that pesky broken ashtray/coin holder
- DIY dual a pillar pod
- How to disconect wires?
- How To Get Results!!
- Fuel Injectors
- Brake Light Socket Replacement
- Changing the Fuel Filter - 2004 Coupe
- this is wierd
- rcm and horn mod now beeps
- Noisy Engine
- Ignition problem, read previous threads, need help asap before work tomorrow!
- looking for some help here, I broke my wind shield wiper arm
- Finding Universal security guard tags
- Instructions For Light Up Door Guards
- repair kit seat heat - install under 2 hrs impossible
- Replacing the Alternator query
- Glass misaligned ?
- Water leakage driverside window
- How to make new emblems front and rear
- How to remove outside door handles
- Discolured Knob
- Removing pop rivets
- 1st Gear "pop-out" recall questions
- valve cover gasket(s) failed
- roadster door rattle
- Programming headlight delay time
- How to Repair Relay Control Module (RCM) - (Mystery no Start)
- Clutch Fluid Reservoir
- Need a Help want to be a dealer
- Full list of part numbers
- Newbie needing how-to help
- how to program door opener?
- Not sure if this has been on here already
- I need Daytime running lights!
- How To: Replace the Washer Reservoir / Tank / Bottle (with pics)
- Using a Uhaul auto transport
- Changing the dash lights
- Removing dent with airduster
- removing crossfire radio
- Blower Control Runs All the Time
- "How to - Horn All of the Time"
- Help Me Before I Break Something
- Help Sprint booster Install
- conv top
- Foggy Crossfire Headlights
- For Newbees and oldies!
- Crossfire cup holder
- Installing cold air intake
- key will not turn
- cracked oil filter housing (reservoir?)
- a GREAT resource for repair diagnosis
- Intake Manifold torque & sequence
- Crossfire Luggage
- Rear hatch rubber stops rubbing off paint?
- How to Manually lower or raise Top on Roadster
- How To: Replace the Fuel Pump Relay Module
- hitting 2nd sucks
- new ditch
- Schedule Maintenance B; (- 51,900)
- Car won't start
- The ongoing saga of the "Surcharge from He!!
- Auto Trans leak Part Deux
- Front fender splash shield part numbers
- Lowered Seats for more headroom
- Mopar windscreen
- Interior light problem
- EuroCharged Lambo-Door conversion kit
- Air Bag Light On After Lighted Accessories Install???
- How to Always on Electric Coolant Pump SRT
- How To - Super Cooler Install
- Looking for car brochure.
- say ello to my lit'l friend
- Has anyone removed DASH, GAUGES BEZAL
- Super Cheap and Fast DIY Oil Changes
- Workshop Manual
- Borrow/rent transmission dip stick
- HOW TO: Make a $6 lower grill, and $20 upper grill
- inside dust filter
- Serpintine belt?
- Hyundai Sonata Recalled for Sharp Door Trim
- battery hold down nut
- Does anybody know what this is?
- Oem Tire Pressure Is Wrong
- Headlights Tsb
- Bas-esp Solved
- New Exhaust
- How do I Jack up my XFire with a FLOOR JACK???
- Air bag module
- door panel removal
- Removing Rear Bar!!!
- HELP! My door speakers need to be replaced. =(
- '04 Coupe Liftgate lock failure
- 7,000 Mile Oil Change?
- NeedsWings Oil Catch Can Kit xfcc - NA Install Guide
- Removing super glue?
- Rear spoiler won't deploy over 60 + mph
- what does the W/S mean
- Chrysler to implement surcharge for all dealer TSB work
- Clunk in rear end
- Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
- HELP! All Dash lights stuck on, Blank Odometer, no radio lights
- ECU Question???
- Something loose behind steering wheel
- I need BIG help
- crankshaft sensor
- Parts Catalog
- Ashtray Light
- Transmission weepage - fixed or messed up?
- How to make your own low profile car ramps
- Report your crossfire reliability Here ???
- security lamps
- Rear Hatch Noise Revisited
- Lube Points
- Headlight Replacement - SRT6
- How to Install Automated Windows
- BlueCrossfire
- Dead Cat at 3100 Miles?
- how many sparkplugs???
- Secondairy air pump code...need help
- Eco/Green detailing tips!
- TSB: Popping Noise From Side Window Area
- Cupholder - problem solved
- Plug removal
- update on grille mod.
- Adjusting mirrors for safe driving
- Failure to Program Key FOB
- Read Only Site - I do not think so
- Signal Mirror Installation
- Ding & Dent Removal
- oil filter question
- oil filters
- Oil Change - Service contracts
- PWR Windows and Germans
- Sprint Booster Question
- I need some advice!
- radio
- our forum in the news!
- Crossfire GPS
- 2008 Crossfire? To buy or not...
- Rear window defrost tabs
- crossfire maybe
- Fan motor campaign to be performed/ horror stories?
- quick dumb question about door lock pins
- someone help! i'm getting screwed
- Heated seat failure
- Service in Phoenix Arizona
