Mp3 unit
Old 03-04-2017, 09:28 AM
Gipeto's Avatar
Default Mp3 unit
Hi, I bought a mp3 unit extension for my stock infinity radio, I linked it to the upper port in the rear of the radio but it doesn't work... any ideas?
Old 03-04-2017, 10:51 AM
Padgett's Avatar
Default Re: Mp3 unit
What "upper port" ? I had to replace he head unit on mine to get BT/USB.
Old 03-05-2017, 03:50 AM
Gipeto's Avatar
The port above the one used by the stock connector... what do you mean whit replace?did you change the radio?Is not possible to manage mp3 unit with stock radio?
Old 03-05-2017, 09:52 AM
Padgett's Avatar
OK here is the complete pinout but I am not sure if all are contained in the Crossfire radio. Think you are talking about the C connector.
Looks like you might be able to use pin 7 as control and 19-20-9 for inputs if they are connected.
Old 03-16-2017, 01:09 PM
Gipeto's Avatar
ok i surrend, the stock non nav radio doesn't manage mp3 unit, only the nav can...so I'm searching for a nav unit but what if i install it without the gps antenna?obviously the gps doesn't work but cd and cd changer (and so the mp3 unit) does?
Old 03-16-2017, 07:48 PM
Toolman's Avatar
The interface will work on the nav radio without the gps antenna being in place, but it will show an antenna error on the right side of the screen. You can buy a compatible gps antenna off of ebay for under $20.
Old 03-17-2017, 05:35 AM
Gipeto's Avatar
good...can you show me wich?
I only must connect to the radio by his port?
Old 03-17-2017, 03:09 PM
Gipeto's Avatar
But a us unit will take signal in Europe?
Old 03-18-2017, 09:32 AM
Toolman's Avatar
This GPS antenna will work with the Crossfire (Becker) Navigation radio.
Mini GPS WICLIC for Mercedes Sony Becker Traffic 4720,4724,7822,7824,7925,7935 | eBay
I believe, but don't know for sure, that there are differences in the European radio frequencies used, and I don't know about the GPS satellites. Most definitely you will need the navigation disks for your location.
