Canada Serving Canada.
Headlight Question
Old 05-05-2014, 02:28 PM
ijaved's Avatar
Default Headlight Question
Hi Guys,
Need some help with headlight. I am putting halo in and I forgot how does the Canadian light switch work i.e. the daylight running lights.
Here is what I think is happening but if someone can verify this that would be awesome.
1- When the car is parked and engine is on the fog light is on.
2- When the car is in Drive (D) the corner projector light is on.
3- This is where I am confused. When you turn the switch on to night light nothing happens. i.e. only the corner project light is on(because car is in D). Do I have a fused low beam light? As per my understanding both projector should be on when this is on. (Fog light goes off)
4- The inner projector light comes on when you high beam someone.
5- Pull the switch the Fog light turns on.
So can someone else confirm these behavior for daylight? Just say 1 = true or correct type deal.
Thank you in advance.
Javed
Old 05-07-2014, 12:23 AM
Default Re: Headlight Question
1-when the engine is on but the gear is in park only the parking light is on
2-when the car is in DRIVE or REVERSE the low beam is on
3- don't know
4-correct
5-correct
Old 05-07-2014, 09:48 AM
ijaved's Avatar
3- don't know
4-correct
5-correct
Thank you so much for your reply.
For #3 I found out that the other projector only turns on high beam.
Jonacross
20
07-17-2017 11:19 PM
Mackel
10-16-2015 09:03 AM
Canyonero
10-06-2015 09:23 PM
lazorouss
09-11-2015 09:16 AM
davidc90
09-06-2015 10:37 PM
Quick Reply: Headlight Question
