tire pressure monitor???
Is there such a device that can tell you the pressure of your tires? If so what are they called and where can you buy one? I have the tire pressure light on in my car and wanted to be able to fix myself rather then bring in for service. What is the recommended pressure for the front ad back again?? And is there something i can buy to help me tell that. Sorry new owner here with no owners manual. Thanks for the help.
Re: tire pressure monitor???
the best place for recommended manufacture tire temperatures is in the drivers door jamb (32/f & 33/r) ... be sure to check the pressure when the tires are cold for accurate readings.
if the pressures are correct... the sensor/dash light should automatically reset itself.
tritongreen
09-18-2015 07:32 AM
