View Poll Results: Is your 6-speed better or worse now than it was before?
Yes, its better.
28
56.00%
No, its worse.
12.00%
I have an automatic, but have a deep emotional need to respond to this poll.
16
32.00%
Voters: 50. You may not vote on this poll
How's your 6-Speed?
on
How's your 6-Speed?
A while ago we had several threads where people discussed the notchiness of the 6-speed and difficulty getting into reverse. I was wondering if adding a few thousand miles has made things better or worse? Personally, after 31,000 miles, the shifting is noticeably better and the getting into reverse problem has virtually disappeared.
Re: How's your 6-Speed?
Really need another option, ie, see no difference.
Or maybe 2 options, see no difference - its a good shifting transmission or: see no difference - still have problems with this pos.
Henry Payne - whose six speed shifts like it did when I bought it, which was good, but its only been a couple thousand miles.
'05 Base - 7,850 miles
on
1 Post
For those of you who noticed the 6-speed car makes a rattling sound when you shut the car off. I discovered the rattling noises are NOT the valvetrain, but it's something in the clutch. Might be the throw out bearing or just a bit of warping in the flywheel. Probably out of tolerance by .003 - .005".
Try stepping on the clutch pedal before you shutdown the car.
I've never had many problems with mine, other than the fact that it's harder to do a 1st-to-2nd shift than a dead stop-to-1st. And the occasional popping out of first when I drive off a curb.
But I'd have to say the shifting is better, but perhaps that is because I'm now used to it...
