CUSTOM Glove Box
Old 06-19-2007, 03:12 PM
blacklimitedcoupe's Avatar
Default CUSTOM Glove Box Trim
I had a couple requests for a polished aluminum piece to fit inside the glove box pull. I've always wanted to cover that area with something and it really makes it look nice now. The piece is made from aluminum and polished to a high gloss. It fits perfectly under the glove box pull and I designed it so it goes up under the glove box pull a small amount so you don't see the top of it. It will come with a piece of 3M double faced tape to apply it. It's a thick enough material that it won't bend. $12 shipped. Below are a few pictures...
Old 06-19-2007, 04:34 PM
Maxwell's Avatar
Default Re: CUSTOM Glove Box
don't they sell theses on ebay.
Old 06-19-2007, 04:36 PM
FP is offline
Not of this quality. What they sell is plastic for more money.
Old 06-19-2007, 04:52 PM
Like FP said, that's why I started making these parts myself because I bought a trim piece from ebay and it was "chrome" but it was actually plastic with fake chrome over it...I didn't like that so I decided polished aluminum would be the way to go...
Old 06-19-2007, 04:53 PM
grphtmtlc11's Avatar
i'll probably order one. please keep making them.
i've already put adhesive-backed aluminum there, but it doesn't look as good as that.
Old 06-19-2007, 05:02 PM
I tried machining them out of super thin aluminum but I didn't like the look of it so I ordered some that is thicker so it can't bend...turned out a lot nicer...
Old 06-19-2007, 08:32 PM
MI1XFIRE's Avatar
I'm going to get one but should I wait for the trim ring we talked about to combine shipping?
Thanks for doing this.
Old 06-19-2007, 08:45 PM
MAYAman's Avatar
OK, I'll order that.
Old 06-19-2007, 08:50 PM
Are you referring to the shifter surround?
Old 06-19-2007, 08:52 PM
MI1XFIRE's Avatar
No I was thinking about the glovebox latch trim ring.
Old 06-19-2007, 08:54 PM
Ohh I started working on that today, should have a finished product by tomorrow.
FP is offline
Ditto...
Old 06-19-2007, 09:38 PM
MI1XFIRE's Avatar
OK I'll take one of each, let me know total $.
Old 06-20-2007, 12:50 AM
04Fire's Avatar
Post pics when you're done... I definitely want one or the other!
Old 06-20-2007, 02:15 AM
snowtop57's Avatar
I'm interested also, but I want to see what the trim ring looks like.
Old 06-20-2007, 03:09 AM
brhertel's Avatar
Ditto, I'll see what else you come up with so I can combine shipping. I love the A/C rings, so I'm excited to see what else you have up your sleeve.
Old 06-20-2007, 08:55 AM
MAYAman's Avatar
Well a nice trim ring polished like the A/C trim rings would be awesome for the glove box IMO. Also if you can make trim that follows the contour of the little things like the mirror switch. The problem with all the trim out there is that it looks like a flat piece of metal. Looks cheap IMO. It has no contour.
Old 06-20-2007, 08:58 AM
MAYAman's Avatar
A perfect example is the shifter surround from other companies. It just sits on top of the plastic and looks tacked on. Looks stupid, any trim for the shifter surround should look like a replacement for the shifter surround. In other words no silver peaking out.
Thanks man I look forward to seeing what you come up with.
Old 06-20-2007, 04:28 PM
FP is offline
If you want to keep going, and I hope you do. Here's a website for more ideas.
http://www.andreschak.de/quaces/inde...0386539d91f532
Old 06-20-2007, 08:36 PM
Thanks FP, some nice ideas...and I will keep going with more parts and I'd be happy to make any custom parts if someone has a good idea... I did finish the glove box trim ring that some people had mentioned...it matches the a/c trim rings and has a lip that fits into the round opening...however the lip isn't enough to hold it because the round opening of the glove box is at a slant...but the lip gives it a cleaner, more factory look...4 small pieces of 3M double faced tape (1 on each side) secures the ring. Here are some pictures...
Quick Reply: CUSTOM Glove Box
