Key Fob programming for door locks
Old 08-25-2009, 09:14 AM
BRappaport's Avatar
Question Key Fob programming for door locks
Hi,
I need a little help from my Crossfire friends...
I know this was discussed before, and I did a search...but could not find it.
Can someone tell me how to program my Key Fob so that BOTH doors open and lock at the same time with one push of the button? Right now, when I hit the Key Fob button to open the doors, only the driver door opens on thr first push. You need to push a second time to open the passenger door.
Thanks
BRappaport
Old 08-25-2009, 09:51 AM
Default Re: Key Fob programming for door locks
Press both lock and unlock buttons at the same time and hold them down until the red light at the top of the key fob blinks.
Old 08-25-2009, 11:06 PM
BRappaport's Avatar
Thanks Series4phaeton...Works great now!
BRappaport
Old 06-27-2010, 03:29 PM
tighed1's Avatar
BUMP!
Just wanted to bump this as some of the attendees at the CAA GTG weren't aware of this procedure.
Press and hold both buttons on the key remote until the light (red lens at top of key fob) blinks twice. Now when you press the open button both doors and trunk will open with one push instead of two!
Repeat procedure to go back to two presses to open passenger door and trunk (why??)
Old 06-27-2010, 03:59 PM
xfchris's Avatar
Location: sandhurst UK..home of the royal military academy
thanks from me as well , not had my XF long and i was wondering about that....
Old 06-27-2010, 04:06 PM
Larry Hitze's Avatar
I never even gave this a thought before. I didn't know it could be done!
Old 06-27-2010, 05:51 PM
Pacemaker's Avatar
Ditto Thanx. My wife is going to LOVE this! It has been awkward for us to run through the rain and get to the car and find MY door is open and she's getting re-baptized!
Thanx again!
Old 06-28-2010, 10:16 AM
Remember That This Was A Safety Factor For At Night Or Other Times So When Your Wife Gets In No One Gets In The Other Side
Old 06-28-2010, 12:06 PM
Originally Posted by tighed1
BUMP!
I spend entirely too much time here to not be aware of this. Were you trying to hide it from us black car owners???
Old 06-28-2010, 02:10 PM
tighed1's Avatar
Nope. Just figured that BLACK Crossfire owners wouldn't need this info since most people wouldn't consider riding in a BLACK XF!
Old 06-28-2010, 02:31 PM
ZAHANMA's Avatar
Nope. Just figured that BLACK Crossfire owners wouldn't need this info since most people woundn't consider riding in a BLACK XF!
Hey Hey, keep your retorts aimed at John hahahaha. I resent you thinking no one wanting to ride with me since mine was black... That has only happened a few times, and she wan't that cute anyways.
Haha. Glad I knew this, Oh wait FOBs aren't working anyways no matter how many times I replace the batteries. Don't feel like shelling out $100/each for new ones yet. Its ok, but I'll re-file this information in the long term area of my brain. It doesn't get used often anyways.
Old 11-28-2011, 07:34 PM
I tried pushing both buttons at same time, waited for red light to blink twice like everyone said, and then tried it. Nothing! Any suggestions?. P.S. The batteries in it are brand new..Thanks!
Old 11-28-2011, 07:40 PM
Found on the forum a way to program it that worked for me!
The Remote Keyless Entry Transmitter(s) can be programmed by the customer without special tools.
PROGRAMMING PROCEDURE
Transmitter programming by the customer is done by performing the following steps:
  1. Insert the key into the ignition switch.
  2. Press either the lock or unlock button momentarily twice.
Turn the key in the ignition switch to the ON/RUN position within 30 seconds.
Hope this is useful and saves you $100.
Old 12-02-2011, 06:38 PM
I've come to rely on this forum to find answers to my questions. This is the first time I stumbled on an answer to a question I hadn't even thought of. I had no idea that the fob could be reprogrammed so that a single push would unlock everything. Cool - Thanks.
Old 12-02-2011, 07:06 PM
Did you also know that even if you don't have the fancy single push top up/down switch, that you can raise and lower both windows fully by pressing the top switch in either direction one quick time, followed immediately by another push ?
( I see that you have a roadster, this does not apply to coupes - as they don't have the magical top switch )
Old 12-05-2011, 02:10 PM
Yes I did know that but thanks for pointing it out anyway. And one of the first things I did when I got the car was to order the new switch module.
Old 09-24-2012, 09:19 AM
Default
Thank you SO much! This was a huge help.
Old 10-03-2012, 11:13 AM
crossfireracr's Avatar
Might need a lil more help guys.
My lights r flashing as if im locking n unlocking my doors but the locks wont actually lock or unlock
Old 10-03-2012, 11:20 AM
Maybe the pump in the trunk is not working or an air/vacuum line is broken.
Old 10-03-2012, 01:58 PM
Are you pushing the lock/unlock button on the center console or the key fob?
Quick Reply: Key Fob programming for door locks
