Engine will not turn over, help
Hoped in the crossfire today and went to turn the key and nothing. All the lights on the dash come on and the light on the wing control comes on. Also the electric fan in the engine compartment comes on when the car has been sitting for over a day. Check the battery and 13 volts, even when the key is turned to the crank position. I disconnected the battery for awhile and hooked it back up with no change.
I have read about the engint control module but most of the guys who have had that problem, have the engine turn over but does not fire. Any ideas ?
on
Re: Engine will not turn over, help
It seems this topic is coming up more and more lately. Some of our members have reported that the relay control module has been the culprit. Just search RCM or mystery no start and you can find the post. However after resoldering my RCM my car is still not cranking sometimes. I checked the RCM thoroughly and it is not malfunctioning. For the majority of the time my car will crank when cold and not crank after being driven a bit.
P.S. I have a new verifiably good battery.
CaughtInaXF (11-30-2022)
Crank and no start - Check the Crank Position Sensor
No crank and no start (duh) - Check the Relay Control Module
Just had another RCM sent to me. Same problem as in previous RCMs.
You folks that have your cars stored for the winter, this would be a good time to check your RCMs.
Remember that it's hard to see with the naked eye. Magnify to really get a good look at it.
Check out this thread
on
Temperature is definately a factor with mine. When the weather gets better I am going to check all grounds and the starter/solenoid. If its not there it may be in the ignition switch or somewhere else. The first time it happened to me I would get a light click when trying to crank and everything else would be functioning normally. Sometimes if I hold the key in the start position long enough it will magically decide to crank. Some may not know that the starter is electronically controlled. If you turn the key to start for just a split second the starter will spin until the car cranks(at least thats what mine used to do).
on
Originally Posted by Karl Von
Reading the other post, I can not belive the electrical issues people have with these cars, mystery non-start, wing goes nuts, dash warning lights, error codes, etc. I did not know I had a Italian car.
I have had the issue while driving at 70 mph and car loses engine power as in total shut down, but still have all electrical functions. Almost got cleaned out by a semi trying to cross from the speed lane to the median 4 lanes over to the right, this has occured 3 times in the last 2000 miles, car will not fire for 5 minutes after stall, then as if nothing ever happened will turn
over as if nothing occured. dealership keeps telling me nothing wrong?
https://www.crossfireforum.org/forum...-no-start.html
Well I solved my problem, I got rid of the car. no more engine check light, ESP lights and worring what is going to go next on the car. I loved the car but it is not worth the head aches. I could understand if this was a cheap kia or other low end car. I should have listen to the reviews on the car, low bid, made on the cheap and over priced. Some one elses problem now.
on
Don't worry we'll get over you leaving us.
I know there are some common problems with these cars (battery can leave you stranded and ACT like it's something else, the RCM can cause at least two different failures that leave you stranded as well, the ignition key/lock can mess up disabling your favorite car, and the CPS can act up as well). But so far, mine is SO worth having.
I hope the next owner shows up here and we can help them really enjoy an interesting and somewhat rare car.
