Please Help New Xfire Owner
on
Re: Please Help New Xfire Owner
.... You can test the horns with the battery..... disconnect the wires at the horn and run two wires from the horn to the battery and touch one to ground and one to the positive(12V) terminal..... did each horn go BEEEEEEEEEP!
If yes, the horns are good.... now you need Doc's meter to test the wiring to the fuses and check for power at the fuses.....
UPDATE!
My friends father is a mechanic. He personaly went through and did everything that was mentioned in prior posts. All connections and fuses are good. Also I took some wire and directly wired the horns to the battery..... they HONKED! I am starting to think that the problem is a horn relay or something spooky like that. Does anyone else think this sounds like a spendy fix? I hope not.
PS. My Grammar is work in progress and I still have multiple years ahead.
Did you have voltage at the horns?
Open up the Relay Control Module the horn relay is in there. If you close the contacts on the correct relay the horn will sound. Which one is it? I'm thinking "C" or the "E" on the right. If not then it's "A" or "B" (could be the other "E" too) I forget at the moment. Just close one at a time and see if the horn sounds. That will check the ground side of the circuit.
on
Originally Posted by XFIORR
UPDATE!
Originally Posted by rfors777
I think that about sums up the future of this once, educated country.
Originally Posted by Catsfire
I'd like to offer a touch of friendly advice. While the written language may not be important to you, it is important to others. When you are seeking the help and guidance of others it is a good idea to adapt and show respect. Poorly written posts are likely to get ignored, (or at least ridiculed) and explaining the reasons for your sloppiness are not valid excuses for disrespect. I apologize if this seems harsh, know that everything counts. I've seen people get amazing job referrals from relationships built on forums like this.
OP this is not directed at you alone, and I applaud your willingness to make an effort.
The same way if you walked up to an older gentleman browsing at the auto parts store and asked for some help with your car, you might get different responses. If you were wearing a baseball cap sideways and your pants hanging off your *** and talked the way you type, I bet the response would not be soo good. If you were dressed normally and spoke eloquently and with respect, I bet he would be more than happy to help. Same situation, but for some reason when you do not have to look a man in the eye, people think they can get away with anything.
remember your talking to a "collage student". by saying touch one side our the other on the fuse will not always make sense! on top of the fuse there are two silver "tabs" you need to take the light probe and touch one of those. touching the colored plastic will not work (make sure you have the clamp end grounded) "attached to a METAL - non painted surface like a nut"
on
I am very limited when it comes to mechanics. I had to get my friends dad to check all they fuses and connections and such because I didn't have the proper tools. I wish more people in iowa had xfires. I would take the RCM out myself, but I fear if I opened the box up my car may never run right again. I may try to mess with the relays but just definately not alone.
-Thank you to all that have posted I appreciate it.
on
I hope you were watching and learning when your friends dad was doing the checking.....
Maybe he would be willing to keep working with you if you're showing an interest in learning and he has the time... if not find someone else who will work with you and teach you... it dosent have to be the same person all the time either... we all do things a little different...
Hey DJ, did you forget the alphabet??? A, B, E, C, E.... whats with that dude?
<--- Huge Horsepower
on
