Oil. Why should I use
on
Re: Oil. Why should I use
I know Chrysler recommends using the Mobil 1 oil, im not sure why. I have used it as well. I would not recommend using the Dollar General Oil as some helpful Senior Member has suggested. I would just stick with what the manual recommends and you will be fine. Sorry I couldnt be of more help.
Depends on how hard the ground is when the pistons and connecting rods come flying out.. you did pay attention to "risk your engine" did you not?
The way I see it. I'd rather spend 2 bucks a quart more and be sure my oil meets the MB specs. I get called cheap for buying 8.50 filters off Ebay instead of buying from the "source" here on the forum.. I can live with it just fine though.. LOL The way I see it there's cheap.. Dollar General Econo SynLube.. and then there's just frugal with a few bucks..
Next time red highlights for the visually impaired.. OKay?
Yes I do follow the FSS. And Dollar General is our only store here..short of the two gas stations. so it's at the top of the approved list.. Unless I'm in Tulsa..
on
